Deletes a MIB view.
all-non-defaults | Specifies that all non-default (non-permanent) MIB views are to be deleted. |
hex_view_name | Specifies the MIB view to delete. The value is to be supplied as a colon separated string of hex octets. |
view_name | Specifies the MIB view name to delete in ASCII format. |
object_identifier | Specifies a MIB subtree. |
N/A.
Use this command to delete a MIB view. Views which are being used by security groups cannot be deleted. Use the all-non-defaults keyword to delete all the MIB views (not being used by security groups) except for the default views. The default views are: defaultUserView, defaultAdminView, and defaultNotifyView.
Use the configure snmpv3 add mib-view command to remove a MIB view from its security group, by specifying a different view.
The following command deletes all views (only the permanent views will not be deleted):
configure snmpv3 delete mib-view all-non-defaults
The following command deletes all subtrees with the view name AdminView:
configure snmpv3 delete mib-view AdminView
The following command deletes the view AdminView with subtree 1.3.6.1.2.1.2
configure snmpv3 delete mib-view AdminView subtree 1.3.6.1.2.1.2
The hex_view_name parameter was added in ExtremeXOS 11.0.
